LAN on 5G-mmWave EVB not working
Regarding EVB user guide,
the 5G-mmWave EVB (with RM530N-GL) provides a LAN interface for connection with PC.
Users can set the modules to PCIe RC mode through LAN interface with AT commands.
For more details about the AT commands, see document [2].
This is all guidance.
I have some questions.
  1. Could you tell me how to setup in detail?
  2. Also, let me know the document[2] " Quectel_xxx&RG530F&RM520N&RM530N_
    Series_AT_Commands_Manual "
  3. How to setup the AQC107 ethernet chipset on the EVB ?
Dear @Trex
I have sent some files to you via Message, hope it can help you.
Thank you so much.
Using the at command manual document you sent, lan worked well.
Please see the attached video file.
I have the same issue, is it possible for you to send the files to me aswell?
Tagging incase you haven’t seen my post @silvia
Silvia, could you please also share the files and instructions also with me ? I have the following board:
RG530F-EU
Revision: RG530FEUEAR05A03M8G
