Hello there,
- What is the flash tool? I downloaded the Qflash.
- Can I have the IIC (i2c) firmware? My current firmware is: $PQVERNO,R,L96NR01A03S,2018/07/30,04:17*6B
Thank you.
Hello there,
Thank you.
Hi @clavisound
I have sent you the relevant information via email, please check.
The upgrade tool is large, please download it from the following path: QGNSS_V2.0_CN | 移远通信
Hello there,
I can understand how to upgrade the firmware with qgnss_v2-0_en__flash_tool.zip from Quectel | Global IoT solutions provider . I tried Firmware download for L96K but it fails. (I can’t send images) Error message: “Model:L96 not suport Download or not exist!” (by the way: “not supported” is the right word)
I tried to select another similar device which has the same chipset - L76, L86 but still receiving the same error.
What is the correct way to update firmware?
I tried to use the QFlash_V7.4 tool but it is not responding when the correct COM is selected.
I have the firmware L96NR11A02SC.zip should I placed in some folder for QGNSS_V2.0?
I can = I can’t (please re-read with I can’t)
@george.gao ping.
Should I try the chinese version of QGNSS_V2.0? Maybe the EN version is different?
Sorry for the confusion. The model is L96-M33 not L96K as I wrote.
