L96 UTC validity
I am reading out the UTC field from the RMC sentence. If the UTC field is populated, is it also always valid? Or do I need to check other fields such as FixMode (in GSA) or Status (in RMC) before the UTC values can be trusted?
Regards
A friendly bump of my own thread
Hi @arurke
It is recommended that you use UTC time after reading valid positioning from RMC or GGA.
Thank you @george.gao . Is it sufficient to check for the RMC Status field being “A” or “D”, or do I also need to check that e.g. the Lat & Lon fields are populated?
Hi @arurke
Just confirm that the “Status” of the RMC statement changes to A. Once the longitude and latitude change to A, the longitude and latitude will have data.
