L96 no satellites at all
Hi there. I have two L96 modules, and neither of them is able to get a GPS fix. No satellites at all. I use the internal antenna. I have seen several threads here about the same problem but without a solution. Could this be a firmware problem? Can I have the latest firmware? The current firmware is:
[2024-12-01 11:10:18.083 Uart Tx:0015 B] $PQVERNO,R3F
[2024-12-01 11:10:18.223 Uart Rx:0044 B] $PQVERNO,R,L96NR11A02S,2023/05/19,11:04
6C
I’m uploading a log file here.
l96log.zip (5.9 KB)
Hi @jeff1974
From the log, we can see that your module did not find any satellites. Please confirm your test environment.
  1. Test in an open, interference-free environment to see if the module can be positioned.
  2. Check if the antenna is loose.
  3. Use an active antenna to test to see if the module can be positioned normally.
  1. I have been using L80s and L86s for almost ten years and those modules can get a fix from here. I don’t think this is an interference problem, because I’m powering the module from USB (using a 3.3V regulator), no MCU on this board, no switching power supply either.
  2. Nothing is wrong with the antenna. This is a brand new module I bought because the first sample didn’t work.
  3. I’ll try an external antenna, but it is a little bit complicated because no connector on this board.
It is working with external active antenna.
Something is wrong here. If I connect an active antenna, it works. If I connect any piece of metal to RFIN that not even looks like a GPS antenna, it works. If I connect together RFIN and RFOUT as I want to use its internal antenna, it doesn’t work.
Hi @jeff1974
From your test results, it seems that the problem is that there is a problem with the internal antenna circuit.
