I’m designing a solution with the L96 module. It could be supply in the 2.8-4.3V voltage range, but it is not clear to me if the I2C pull-up resistors can be connected to the power supply line. In fact in your notes you reported the following points:
- I2C_SDA/I2C_SCL should be externally pulled up to 2.8V.
- The voltage threshold of I2C is 2.8V. If the system voltage is not consistent with it, a level shifter circuit must be used.
If the voltage threshold is 2.8V, pull up resistors have to reference to a higher voltage, e.g. the power supply voltage, as it is for all integrated circuits with I2C ports.
So, can you confirm the maximum voltage for pull-up resistors please?
Thank you and best regards
