L96 EVB, no satellite received, no fix
For test purposes I am using a L96 EVB without external antenna. I don’t see any satellites and I don’t have a fix. Is it possible that the L96 has such a bad performance in a city?
best regards
Matthias
Hi Matthias,
Did you test EVB indoors? It’s difficult to receive satellite signal when L96 using a passive antenna indoors. Passive antenna requires more signal than a active antenna. Because passive antenna don’t have LNA to amplify satellite signal.
Best regards.
