Hello.
Coud you explain a behavior of 3D_FIX pinout?
Only I see in Hardware Design is “The 3D_FIX is assigned as a fix flag output. The pin will output a high voltage level to indicate successfull positioning.”
I’d like to use the pin to wake up main MCU.
Questions:
- What “fix flag output” does it mean (Fix Status of GSA or Valid/Invalid of RMC) ? in what output or PMTK-command/response
- Can pinout be programmed for 2D only or 3D only or 2D/3D fix?
- What PMTK commad described in Protocol Spec manages it?
