I powered up the L89HD. Leaving the BROM messagage is appearing every 3 second. Is it rebooting itself?.
I checked the VCC using ossciloscope and it is stable at 3.3V.
I sent PAIR commands and getting acknowledgement as shown below
Hi @N_N the PAIR062 command is to set the NMEA output rate. Your command was to disable NMEA_SEN_GSA.
Once send out the command please save the parameter using below command and reboot the module.
$PQTMSAVEPAR*5A
Can you share the firmware version and the NMEA log as well?
Best Regards,
hi,
The version is $PQTMVERNO,L89HDNR01A01S_DQN,2024/07/25,16:15:41*3D
Also I attached the NEMA messages..
It keeps on rebooting every 3 second..
Nema_Messages.txt (8.4 KB)
Regards,
Hi @N_N can you share your setup and how you connect the module? Also please share your schematic design if available as this rebooting issue is potentially due to HW issue.
Please share to this email: mohamad.firdaus@quectel.com
Best regards,
I have left following pins Not Connected : WDI_SET, WI, FWD, WHEELTICK, RESET, V Back, 1 PPS, WAKEUP, JAM_IND, GEOFENCE.
Should I pull down WDT pin , rather than floating. I check voltage on WDT pin.. it is at 2V.. but VCC is at 3.3 V
I will try to mouting again the IC , may be solder connection is not good.
Will update you with schematic.
Please close this query.. The issue has been resolved.
pulled down the WDT pin
