I am using L89H module, which is giving $GNRMC. So, can you provide set of commands by which i can configure the module to operate in only GPS configuration and provide $GPRMC packet.
If any queries, please revert.
Hi Temc,
Set GPS only search mode: $PAIR066,1,0,0,0,0,0*3B
Configure NMEA sentences output:
$PAIR062,0,0*3E //GGA OFF
$PAIR062,1,0*3F // GLL OFF
$PAIR062,2,0*3C // GSA OFF
$PAIR062,3,0*3D //GSV OFF
$PAIR062,4,0*3A //RMC OFF
$PAIR062,5,0*3B //VTG OFF
$PAIR062,6,0*38 //ZDA OFF
$PAIR513*3D //save configuration
Best regards.
Thank you for the response,
We require L89H module to work with NMEA v 3.01 and should provide $GPRMC packet with same version.
I have an existing project which is working on NMEA v 3.01, for which the code cant be changed as it is safety certified.
Can you suggest me how we can achieve this ?
Hi Temc,
You can set NMEA v3.01 by $PAIR100,2,0*39.
If you want to output $GPRMC, please set GPS only search mode.
So the command list is:
$PAIR100,2,0*39
$PAIR513*3D // save configurations
restart the module
Best regards.
Thank you for the commands, the module is working as per our intended application.
Where can I get this list pf PAIR commands ?
