L89 Vbackup Rechargable battery connection
Hi
i am using L89 GPS module and for the Vbackup i am using a 3.7v Lithium Polymer battery.
For charging from 5v i connect 2 nos of 1N4007 diodes which reduce the 5v to 4.2v and it charge the battery well.
But the problem is once the battery get charged the current goes below 1ma and now the forward voltage drop of the diodes reduced and the 5v is applied to the Vbackup pin. Is it safe and is there any simple circuit which can charge the battery and drive the vbackup pin safely.
Binu
Hi Binu_Johnson,
I suggest you design Vbackup circuit according to the L89_Hardware_Design
Please find the document attached. Hope it helps.
Best regards.
Quectel_L89_Hardware_Design_V1.1.pdf (822.5 KB)
Hi, its working fine now.
Whats the latest firmware which support to receive broadcast message from Navic
Hi Binu_Johnson,
L89 support IRNSS, you can enable IRNSS by sending $PSTMSETCONSTMASK,1024
L89 is is supporting all satellites, but we would like to connect only to IRNSS, How to Disable all other satellites ?? Please support..
