Hello, I have bought multiple L86 GNSS modules for personal projects, and faced a problem regarding satellites detection. GNSS module finds satellites and receives GPGSV commands. But once I move it to a place with no connection, like basement - it loses all signal, which is OK, due to connection absent.
The problem is that once I move tag back outside - it does not see any satellites for hours.
I tried multiple modules, and all have the same problem.
Is this common issue? Should I explicitly reload GNSS using its PMTK commands?
Looking forward for your help, best regards
Hi SergeyKotovshiko
Please use the “$PQVERNO,R*3F” command to check the version of the module and let me know.
Hi George. I apologize for taking so long to respond. I didn’t expect such fast support)
Response for this command is following:
$PQVERNO,R,L86NR03A01S,2020/02/27,02:4264
$GPVTG,0.00,T,M,0.00,N,0.00,K,N32
$GPGGA,114026.359,0,0,M,M,47
$GPGSA,A,1,103
$GPGSA,A,1,200
$GPGSA,A,1,301
$GPGSV,1,1,00,065
$GLGSV,1,1,00,178
Hi SergeyKotovshiko
Please use QGNSS tool to download the firmware. QGNSS tool download link: QGNSS_V1.10_CN | 移远通信 (quectel.com.cn)
I will send you the latest firmware and firmware download instructions via Message. Please try upgrading to the latest software.
