Hello all. Apologies if this has been covered elsewhere.
We’re using an L86 with external antenna, waiting up to 12.5 minutes for the first fix, then sending standby mode command ($PMTK161,0*28). The first fix is usually found within 3 minutes. After an hour we issue a command to switch to Full On mode.
How long should it take to get a new position after leaving Standby mode ?
It appears there are multiple satellites available, but time out after 30 seconds waiting for the next valid GPMRC position.
Any insight would be appreciated.
10:26:11.765 -> $GPRMC,152610.486,V,0.00,0.00,070621,N,V3E
10:26:11.834 -> $GPVTG,0.00,T,M,0.00,N,0.00,K,N32
10:26:11.869 -> $GPGGA,152610.486,0,0,M,M,43
10:26:11.904 -> $GPGSA,A,1,103
10:26:12.160 -> $GPGSA,A,1,200
10:26:12.160 -> $GPGSV,4,1,13,14,69,000,17,67,270,30,60,184,28,58,326,062
10:26:12.160 -> $GPGSV,4,2,13,01,46,067,21,19,40,246,21,27,048,31,07,24,159,068
10:26:12.160 -> $GPGSV,4,3,13,13,23,270,22,09,086,06,07,195,15,06,296,062
10:26:12.160 -> $GPGSV,4,4,13,03,04,111,051
10:26:12.215 -> $GLGSV,1,1,00,178
10:26:12.215 -> $GPGLL,152610.486,V,N71
10:26:12.250 -> $GPTXT,01,01,02,ANTSTATUS=OK3B
