Dear Support,
I am currently evaluating L76K GPS module.
First of all, I haven’t found any Quectel doc targeting L76K specifically. Is GNSS L76 | Quectel link correct for documents applicable to L76K module?
Provided the above is true, the Lx6&LC86L&LG77L Series GNSS Protocol Specification document specifies following vendor-specific commands:
- PMTK101 PMTK_CMD_HOT_START
- PMTK102 PMTK_CMD_WARM_START
- PMTK103 PMTK_CMD_COLD_START
- PMTK104 PMTK_CMD_FULL_COLD_START
- PMTK161 PMTK_CMD_STANDBY_MODE
Application logic I am planning to use for the product I am working on is based on following scenario:
(1) put the L76K into low-power state by switching-off VCC supply via transistor (while keeping V_BCKP powered)
(2) wake-up the L76K after application-specific time period (i.e. 24 hours) by switching-on VCC supply
(3) wait for GPS fix
(4) save the GPS location on microcontroller driving L76K
(5) start-over with step (1)
I have following questions regarding the steps above:
- is this scenario aligned with Quectel recommendations for low-lower L76K GPS periodic location acquisition?
- should be L76K put into STANDBY_MODE before step (1) or it does not matter?
- Doc for PMTK_CMD_HOT_START mentions that:
“Normally a hot start means the GNSS modules are powered down less than 2 hours with RTC in operation and the ephemeris is still valid. As there is no need for downloading ephemeris, it is the fastest startup method”
Does it mean PMTK_CMD_COLD_START shall be manually triggered on L76K after step (2) when more than 2 hours elapsed since last GPS fix?
- Does
PMTK_CMD_*_STARTmatter after VCC is switched-off and switched-on in steps (1) & (2) given the V_BCKP is always powered? Or switching VCC off and on forces the cold start on L76K despite backup data?
I am looking forward for answers for the questions above to properly utilize L76K in the product I am working on.
Best regads,
Nikodem
