What is the default value for the minimum SNR (after removal of backup power or execution of PMTK104 command). Thanks!
Do you mean, what is the minimum SNR value required after a cold start?
What I mean is: if I send PMTK104 command (factory reset) and do not send any PMTK306 command (set minimum SNR), what value does the L76 module use? Thanks!
8 GPS satellites are about 24dbm.
