I have a set of 6 L76-L based systems running in our test lab. Recently 2 of the 6 jumped and now stuck in July 2046.
They were reporting correct time, but now are constantly reporting 1024 weeks into the future.
The 4 working systems are: reporting correct date, using GPS+GAL+GLO.
The 2 non-working systems are: reporting correct time, but date is +1024 weeks, and reporting SNR for GPS+GAL, but only GAL is used.
$GNRMC,124124.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,020746,A,V*0E
NOTE Date 02-07-46 above
Here’s some of the NMEA stream. (coordinates replaced with XXXX):
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.26,7.20,0.94,3*01
$GPGRS,124122.000,1,-0.64,-11.5,-14.4,22.0,20.1,1.58,,,,,,3,0*73
$GPGST,124122.000,9.0,27,7.3,172.8,27,8.0,36*43
$GNZDA,124123.000,02,07,2046,,*4A
$GNRMC,124123.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*09
$GPGGA,124123.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.21,111.9,M,-33.4,M,,*65
$GNGSA,A,3,,,,,,,,,,,,,7.27,7.21,0.94,1*0A
$GNGSA,A,3,,,,,,,,,,,,,7.27,7.21,0.94,2*09
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.27,7.21,0.94,3*01
$GPGSV,2,1,08,44,23,236,35,13,,,46,10,,,24,02,,,29,0*50
$GPGSV,2,2,08,23,,,43,01,,,26,24,,,32,12,,,42,0*6C
$GLGSV,2,1,08,67,35,062,,74,34,308,,68,30,124,,84,29,285,,1*7D
$GLGSV,2,2,08,80,07,194,,66,04,014,,75,02,345,,69,01,162,,1*7B
$GAGSV,3,1,11,19,74,338,18,28,53,278,29,12,49,250,,10,43,286,26,0*71
$GAGSV,3,2,11,29,39,066,35,04,29,270,30,11,26,314,,27,23,070,23,0*7B
$GAGSV,3,3,11,21,21,125,,06,05,263,,30,04,027,,0*44
$GPGRS,124123.000,1,-0.95,-10.9,-14.9,22.2,19.6,1.51,,,,,,3,0*7A
$GPGST,124123.000,9.0,29,7.3,172.3,29,8.2,36*4B
$GNZDA,124124.000,02,07,2046,,*4D
$GNRMC,124124.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*0E
$GPGGA,124124.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.22,111.9,M,-33.4,M,,*61
$GNGSA,A,3,,,,,,,,,,,,,7.28,7.22,0.94,1*06
$GNGSA,A,3,,,,,,,,,,,,,7.28,7.22,0.94,2*05
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.28,7.22,0.94,3*0D
$GPGRS,124124.000,1,-1.26,-10.4,-15.0,25.0,18.7,0.72,,,,,,3,0*74
$GPGST,124124.000,9.0,31,7.3,171.8,31,8.5,36*43
$GNZDA,124125.000,02,07,2046,,*4C
$GNRMC,124125.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*0F
$GPGGA,124125.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.22,111.9,M,-33.4,M,,*60
$GPGRS,124125.000,1,-1.92,-9.26,-14.1,27.7,18.2,0.12,,,,,,3,0*74
$GPGST,124125.000,9.0,34,7.4,171.4,34,8.9,37*44
$GNZDA,124126.000,02,07,2046,,*4F
$GNRMC,124126.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.98,,020746,,,A,V*0D
$GPGGA,124126.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.23,111.9,M,-33.4,M,,*62
$GNGSA,A,3,,,,,,,,,,,,,7.30,7.23,0.94,1*0E
$GNGSA,A,3,,,,,,,,,,,,,7.30,7.23,0.94,2*0D
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.30,7.23,0.94,3*05
$GPGRS,124126.000,1,-2.50,-8.73,-13.4,28.4,17.9,-0.23,,,,,,3,0*5E
$GPGST,124126.000,8.9,37,7.4,171.2,36,9.2,37*42
$GNZDA,124127.000,02,07,2046,,*4E
$GNRMC,124127.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*0D
$GPGGA,124127.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.24,111.9,M,-33.4,M,,*64
$GNGSA,A,3,,,,,,,,,,,,,7.30,7.24,0.94,1*09
$GNGSA,A,3,,,,,,,,,,,,,7.30,7.24,0.94,2*0A
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.30,7.24,0.94,3*02
$GPGRS,124127.000,1,-2.70,-7.93,-9.68,31.5,17.3,-0.80,,,,,,3,0*57
$GPGST,124127.000,8.9,37,7.4,171.3,37,9.3,37*42
$GNZDA,124128.000,02,07,2046,,*41
$GNRMC,124128.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.99,,020746,,,A,V*02
$GPGGA,124128.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.24,111.9,M,-33.4,M,,*6B
$GPGSV,2,1,08,44,23,236,35,13,,,46,10,,,22,02,,,28,0*57
$GPGSV,2,2,08,23,,,43,01,,,22,24,,,32,12,,,42,0*68
$GAGSV,3,1,11,19,74,338,17,28,53,278,29,12,49,250,,10,43,286,26,0*7E
$GAGSV,3,2,11,29,39,066,35,04,29,270,30,11,26,314,,27,23,070,22,0*7A
$GPGRS,124128.000,1,-1.99,-7.49,-6.79,33.6,17.1,-0.75,,,,,,3,0*5D
$GPGST,124128.000,8.9,37,7.3,171.6,36,9.0,36*4C
$GNZDA,124129.000,02,07,2046,,*40
$GNRMC,124129.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,1.36,170.04,020746,,,A,V*1B
$GPGGA,124129.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.25,111.9,M,-33.4,M,,*6B
$GNGSA,A,3,,,,,,,,,,,,,7.31,7.25,0.94,1*09
$GNGSA,A,3,,,,,,,,,,,,,7.31,7.25,0.94,2*0A
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.31,7.25,0.94,3*02
$GPGRS,124129.000,1,-0.98,-7.75,-3.57,32.8,15.8,0.15,,,,,,3,0*75
$GPGST,124129.000,8.9,37,7.3,171.6,37,9.0,36*4C
$GNZDA,124130.000,02,07,2046,,*48
$GNRMC,124130.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,1.19,170.40,020746,,,A,V*1E
$GPGGA,124130.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,6,7.26,111.9,M,-33.4,M,,*60
$GNGSA,A,3,,,,,,,,,,,,,7.32,7.26,0.94,1*09
$GNGSA,A,3,,,,,,,,,,,,,7.32,7.26,0.94,2*0A
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,7.32,7.26,0.94,3*02
$GPGRS,124130.000,1,-2.03,-7.75,-0.71,31.9,15.0,-0.16,,,,,,3,0*5E
$GPGST,124130.000,8.9,38,7.3,171.6,37,9.1,36*4A
$GNZDA,124131.000,02,07,2046,,*49
$GNRMC,124131.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,2.77,2.30,020746,,,A,V*17
$GPGGA,124131.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,11,1.14,111.9,M,-33.4,M,,*50
$GNGSA,A,3,13,02,23,24,12,,,,,,,,1.44,1.14,0.88,1*00
$GNGSA,A,3,,,,,,,,,,,,,1.44,1.14,0.88,2*07
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,1.44,1.14,0.88,3*0F
$GPGRS,124131.000,1,-13.8,74.0,-40.9,1.18,25.5,5.00,-1.76,-10.9,3.99,-0.52,-1.02,15,0*78
$GPGST,124131.000,8.9,23,6.7,177.6,23,6.8,38*4F
$GNZDA,124132.000,02,07,2046,,*4A
$GNRMC,124132.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,2.41,2.30,020746,,,A,V*1E
$GPGGA,124132.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,11,1.14,165.9,M,-33.4,M,,*5F
$GPGRS,124132.000,1,-6.52,62.6,-22.0,3.11,17.9,3.94,1.06,-8.90,3.67,-0.65,-1.15,15,0*51
$GPGST,124132.000,8.9,19,6.4,00.8,19,6.4,38*7C
$GNZDA,124133.000,02,07,2046,,*4B
$GNRMC,124133.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,2.15,2.30,020746,,,A,V*1E
$GPGGA,124133.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,11,1.13,165.6,M,-33.4,M,,*56
$GNGSA,A,3,13,02,23,24,12,,,,,,,,1.44,1.13,0.88,1*07
$GNGSA,A,3,,,,,,,,,,,,,1.44,1.13,0.88,2*00
$GNGSA,A,3,04,27,10,19,28,29,,,,,,,1.44,1.13,0.88,3*08
$GPGSV,2,1,08,23,48,144,43,13,36,091,46,12,30,082,42,24,23,052,32,0*65
$GPGSV,2,2,08,44,23,236,35,02,19,308,28,10,,,23,01,,,18,0*6E
$GAGSV,3,1,11,19,74,338,17,28,53,279,29,12,49,250,,10,43,286,25,0*7C
$GAGSV,3,2,11,29,38,066,35,04,29,270,31,11,26,314,,27,23,069,23,0*73
$GPGRS,124133.000,1,-1.00,52.1,-6.97,3.87,11.7,2.59,3.94,-7.77,4.29,-0.68,-2.73,15,0*57
$GPGST,124133.000,8.9,15,6.1,05.9,15,6.3,39*7A
$GNZDA,124134.000,02,07,2046,,*4C
$GNRMC,124134.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*0D
$GPGGA,124134.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,11,1.14,165.5,M,-33.4,M,,*58
$GPGRS,124134.000,1,-1.18,49.1,-3.91,3.20,12.2,1.05,3.01,-6.95,1.43,-0.58,-3.10,15,0*5E
$GPGST,124134.000,8.8,15,6.0,07.2,15,6.2,39*75
$GNZDA,124135.000,02,07,2046,,*4D
$GNRMC,124135.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*03
$GPGGA,124135.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,12,1.07,165.2,M,-33.4,M,,*50
$GNGSA,A,3,13,02,23,24,12,,,,,,,,1.39,1.07,0.88,1*08
$GNGSA,A,3,,,,,,,,,,,,,1.39,1.07,0.88,2*0F
$GNGSA,A,3,04,27,10,19,12,28,29,,,,,,1.39,1.07,0.88,3*04
$GPGRS,124135.000,1,-0.96,44.3,-2.46,2.33,12.2,0.55,2.31,-4.36,-0.93,0.76,-0.81,-3.04,3,0*76
$GPGST,124135.000,8.6,14,5.8,07.9,14,6.1,39*79
$GNZDA,124136.000,02,07,2046,,*4E
$GNRMC,124136.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*00
$GPGGA,124136.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,12,1.07,165.2,M,-33.4,M,,*53
$GPGRS,124136.000,1,-0.50,42.1,-1.64,0.80,8.30,-0.05,2.16,-0.90,-2.38,-3.17,-0.15,-3.82,3,0*74
$GPGST,124136.000,8.5,14,5.7,08.4,14,6.0,39*75
$GNZDA,124137.000,02,07,2046,,*4F
$GNRMC,124137.000,A,XXXX.XXXX,N,XXXXX.XXXX,W,0.00,,020746,,,A,V*01
$GPGGA,124137.000,XXXX.XXXX,N,XXXXX.XXXX,W,1,12,1.07,165.2,M,-33.4,M,,*52
$GPGRS,124137.000,1,-0.62,40.3,-2.20,0.59,9.91,-0.50,1.71,2.32,-1.95,-2.82,-1.64,-4.37,3,0*5B
$GPGST,124137.000,8.4,14,5.7,08.4,14,6.0,39*75
