When the L76 wake-up from backup mode he perform a warm startup?
How many constellation can i use simultaneous?
When easy is on i can set fix rate to less than 1Hz?
Hi Cleberhaack,
The ephemeris data is vaild for 2 hours. If L76 entered backup mode and woke up within 2 hours, it performs a hot startup. When back up time exceeds 2 hours, the ephemeris data is invalid, so it performs a warm startup. In this case, you need to inject the latest ephemeris data if you want to improve TTFF.
L76 can use 23~28 satellites simultaneously.
Yes, you can set fix rate less than 1Hz.
Best regards.
Hi Raphael,
I can use glonas, galileo and GPS in the same time?
