i have more L50 modules, they are running, but the number of satellites has been low, since April 2019.
I received information about the weeks counter problem.
i found an update opportunity here:
http://www.quectel.com/ProductDownload/L20&L30&L50%20documents.zip
I follow the patch description but I always get an error message.
can someone help me?
log:
********START OF LOG SESSION *********
Log File Logs.txt Opened
------CSR GSD ROM Patch Application------------
------Version: 3.2, Date: 11/11/2015------------
PatchMgr Input Configuration :
UART COM4 115200 OSP 115200 FALSE GSD4e_4.1.2_P1_RPATCH_10.pd2 Logs.txt
------Opening COM Port-----
COM Port Open at 115200 baudrate(SUCCESS)
Protocol: OSP
------Setup And Verify Communication with Rx-----
Trying At BaudRate = 115200
Trial 1
Initial Commn Established…(SUCCESS)
------Handling Power Mode -----
Trying To Get Receiver Power Mode Parameters
Polling NAV
Retry Polling NAV
Continuous power enabled
MaxAcqTime = 120000 ms; MaxOffTime = 30000 ms
Receiver Started in FULL POWR MODE
------Process, Load and Apply Patch-----
Only ARM patches exist in the input patch file
------Load ARM patch file-----
CRC passed! Calc CRC = 0x2d6b3af3, PD2 CRC = 0x2d6b3af3
Overlay Section CRC = 0x28d7f104
Non-Overlay Section CRC = 0x470de711
Error 14: PM prompt msg not compatible with Rx
OSP: State machine recovery
Error 14: Did not receive PMPrompt response
------Restoring Initial Power Mode Settings of Rx-----
Rx Started in FULL POWR, No POWR Mode Changes Required
------Restoring Initial Comm Settings of Rx-----
Initial Settings of Receiver Restored
COM Port Closed
RESULT
Summary: FAILURE - Patch load was not successful. Error Code 14.
*********END OF LOG SESSION **********
