we are currently testing/evaluating the “L26-DR (U)”. In the document “Quectel_L26-DR_GNSS_Specification_V1.3-4.pdf” it is stated, that the UDR version of the module supports output rates up to 10Hz.
However I’m searching for the correct command to configure a higher output rate of the NMEA messages?
For this I have the document “Quectel_L26-DR_GNSS_Protocol_Specification_V1.1_Preliminary_20200630.pdf” available.
At first I thought, that this could be done with the “rate” parameter of the “$PSTMCFGMSGL” command. However if I set this parameter to 5 (for 5Hz) the module acknowledges this command and then just restarts without changing the output rate.
The module firmware: PSTMSETPAR,1500,L26UDRNR01A04V02_SCY
Thank you very much!
The commands work as intended.
May I ask if the Quectel_L26-DR_GNSS_Protocol_Specification_V1.1_Preliminary_20200630.pdf will receive an update and be officially downloadable from quectel.com in the near future? Currently I do not find any corresponding documentation there:
