when should I send a validity flag as valid or not valid?
Hi:
- It needs an application framework that can use a map matching system (for example, in a navigation system).
- Judge whether the location information output by L26-DR is valid through the host’s map matching system (including the location database of the map).
In addition, we can discuss the same issue in one post.
Thank you.
