L26-DR GNSS - messages returned by the module after or before reset?
Hi, the L26-DR GNSS Protocol Specification says, for example:
2.3.19. $PSTMCFGAGPS
This command configures the Assisted GPS. The setting can only take effect by issuing the saving
command (i.e. $PSTMSAVEPAR) and, then, resetting the system (through $PSTMSRR). Once saved,
the configurations will persist even after a power cycling.
If no error occurs, the following message will be returned: $PSTMCFGAGPSOK*
In case of errors, this error message is returned: $PSTMCFGAGPSERROR*
so, when do we receive these messages of ERROR or OK, after or before resetting the module?
thanks
Normally, the module will return soon.
Please help provide L26-DR version information through this query command ā€œ$PSTMGETPAR,1500ā€.
Best Regards
hi,
what means soon?, I can“t perform that test now because I don“t have the module yet
Within 1s.
I think it would be better to test and verify after you have the module.
In addition, resetting the module generally requires the command to be sent successfully.
Best Regards
