Hi, the L26-DR Application Note page 25 says we should perform a procedure to calibrate the DR, I want to use the UART speed mode so as I understand the module calibration should start after sending the $PSTMSETPAR and $PSTMDRSENMSG (this each 10Hz minimum), but what if I want to recalibrate the DR?, should I erase the NVM? or stop sending the commands mentioned before and start sending them again to start the calibration mode?
thanks
