Hi, I am using the $PSTMCFGMSGL command to enable/disable some messages, I only want the GPRMC and GPGGA, I use this message:
$PSTMCFGMSGL,0,1,00000042,00000000
$PSTMSAVEPAR
$PSTMSRR
the module accepts those commands but I still receive the $PSTMDRSENMSG message, why?
I also use $PSTMGETPAR,1201 and $PSTMGETPAR,1228 to confirm the configuration and I get:
$PSTMSETPAR,1201,0x00000040 and PSTMSETPAR,1228,0x00000000
The current version does not support closing the $PSTMDRSENMSG message. The next version will support closing. It is planned to be released around June.
Best Regards
So this new version already exists? If it does, where can I find it? It’s actually a problem to find any versions to upgrade the L26-DR, if you have a link to that I would be thankful!
Dear Sir
Sorry, there is no new official firmware released yet.
Best Regards
Hi @Stone.Chen-Q any update about the firmware?, thanks
Hi @jg_spitfire ,
Please find the firmware via your private message.
Best regards
according to the doc in the new firmware the PSTMDRSENMSG now could be disabled, thanks
