I would like to use the KG200Z module, but I want to develop my own embedded firmware for the MCU inside the module. Is this possible?
I noticed that the module contains an STM32 microcontroller. Can I develop and program my own firmware using STM32CubeMX and STM32CubeIDE, just as I would with a standard STM32 MCU?
If this is supported, could you please let me know whether the necessary documentation, SDK, or programming/debugging interface is available?
Yes, you can program the KG200Z (run on an STM32WLE5JC chipset) either using STM32Cube tools directly (RTOS) or using QuecOpen, our dedicated C programming library that already has most basic functions defined, unlike doing it fully manually where you’d need to set up RTOS yourself. So essentially there are 3 solutions:
(1) Run AT commands directly with our public release standard AT firmware (requires an external MCU to run)
(2) Compile your own firmware using QuecOpen SDK in standalone mode — this already runs on top of an RTOS with the framework and APIs pre-built for you, and it’s compiled/flashed using STM32CubeIDE + STM32CubeProgrammer (same tools as option 3, but you skip most of the manual RTOS/peripheral setup)
(3) Compile using STM32CubeMX (for peripheral/clock/RTOS configuration) + STM32CubeIDE (to write and build the code) in standalone mode — here you configure and manage the RTOS (e.g. FreeRTOS) yourself
For QuecOpen access, you need to apply through us — I’ve sent the questionnaire to you via email.
To directly answer your question: STM32CubeIDE is used in both (2) and (3), it’s the IDE either way. STM32CubeMX is only really needed for path (3), since QuecOpen already handles the RTOS/peripheral setup for you. Happy to go over the KG200Z details whenever you’re ready.
Do we need to pay any additional fee to use the QuecOpen SDK? Also, did I understand correctly that I can develop my own embedded firmware using STM32CubeIDE and STM32CubeMX without any issues or additional licensing fees?
You don’t need any fee to use the QuecOpen SDK, usually we will need some form for application, that’s all. You may use the questionnaire sent last time.
Yes, you can do programming directly as well using STM32CubeIDE and STM32CubeMX without any issues.
QuecOpen is based on the latter and has made hardware adaptations and provided examples for the KG200Z module, facilitating direct development on the module.
