I am using Quectel EC20 (CE) in which If I connect other operators like Airtel, Vi they are getting connected and it dialling with wvdial but when I am using Jio SIM it’s not getting network but while I checked with other modems the Jio SIM is getting network and connecting to the internet also.
Please let me know how to resolve it.
Hi Saurabn_Roy
It may be because of the APN problem, please check what is the APN used by jio, and then use the at command to modify it, AT+CGDCONT=[,<PDP_type>[
,[,<PDP_addr>[,<data_comp
[,<head_comp>[,<IPv4_addr_alloc
[,<request_type>]]]]]]]
Best wishes
Thankyou @FelixCheng-Q
But here I can see that AT+COPS? is giving me 0 response ,In other SIM I am getting Operator name .
AT+COPS=? giving me this response
Hi @Saurabh_Roy,
I was also facing the same issue but when I upgraded the firmware and added some related LTE files then the issue was resolved for me. You can try updating the firmware files it should help
Regards
thankyou @MaazSk
Where can I get the updated firmware?
Hi MaazSK
Where did you get the module? Please get the latest firmware from the module section
Best wishes
Hi FlixCheng,
I purchased the module from one of your authorized dealers and they supported me in resolving this issue
Regards
Hi @Saurabh_Roy,
You can find the updated firmware here.
They were discussing how to get updated EC-20 firmware.
Regards
Thankyou @MaazSk ,I will check with new firmware
@MaazSk This link is already deleted ,Do you have any other link
Did you solve the problem?
