I’m using the EC200U module on my custom board, which is based on the NXP RT1170 microcontroller, and I’m using MCUXpresso as my IDE. The diagram below represents my hardware design.
In my program, I am creating a pulse in order to turn on the module. The following commands are used:
GPIO_WritePinOutput(GPIO3, 22, 1U);
SDK_DelayAtLeastUs(4294967, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY);
GPIO_WritePinOutput(GPIO3, 22, 0U);
This will create a delay of more than 2 seconds, as referenced in the datasheet
Next, I am transferring the ‘AT’ command through UART, and as a result, I should receive ‘OK’, right? However, I’m not receiving anything. Where might I be making a mistake? Do I need to configure anything else using AT commands before sending just the ‘AT’ command?
