Issues trying to connect Quectel MC90 to AWS via MQTT
I am facing some issues trying to connect an MC90 module to AWS. When I try to open the connection with QMTOPEN it returns: -1 Failed to open network.
I have followed the GSM MQTT Application Note v1.3 but it seems that there is a step I’m not doing properly. I double ckecked that the APN, IP address, user, pass.. are correct. I have also used some commands from the MC60&MC90 AT Commands Manual. In the SIM provider’s website I can see that there is data being transmitted and received. I am also able to make a ping. Because of this I think that maybe the problem is with the certificates or with how I try to connect to AWS. As consequence, I have tested different configurations and diferent certificates, but they don’t work neither. At this point I’m not sure how to continue. Some suggestion or idea is appreciated.
Below you can find attached the log. Thanks in advance. BR.
ATI
Quectel_Ltd
Quectel_MC90
Revision: MC90CAR01A04
Call Ready
SMS Ready
AT+QSSLCFG="ctxindex",2
AT+COPS=0
ATE1
AT+CMEE=2
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,5
AT+CGATT=1
AT+CGATT?
+CGATT: 1
AT+QIREGAPP="*apn*","*user*","*pass*"
AT+QICSGP=1,"*apn*","*user*","*pass*"
AT+CGDCONT=1,"IP","*apn*","*ip*"
AT+CGDCONT?
+CGDCONT: 1,"IP","*apn*","*ip*",0,0
+CGDCONT: 2,"IP","","",0,0
+CGDCONT: 3,"IP","","",0,0
AT+CGREG?
+CGREG: 0,5
AT+CGACT=1
 AT+CGACT?
+CGACT: 1,0
+CGACT: 2,0
+CGACT: 3,0
AT+QISTAT
STATE: IP START
AT+QMTCFG="SSL",0,1,2
AT+QSECWRITE="RAM:cacert.pem",1187,100
CONNECT
+QSECWRITE: 1187,3900
AT+QSECWRITE="RAM:client.pem",1220,100
CONNECT
+QSECWRITE: 1220,3019
AT+QSECWRITE="RAM:user_key.pem",1679,100
CONNECT
+QSECWRITE: 1679,2511
AT+QSSLCFG="cacert",2,"RAM:cacert.pem"
AT+QSSLCFG="clientcert",2,"RAM:client.pem"
AT+QSSLCFG="clientkey",2,"RAM:user_key.pem"
AT+QSSLCFG="seclevel",2,2
AT+QSSLCFG="sslversion",2,4
AT+QSSLCFG="ciphersuite",2,"0xFFFF"
AT+QSSLCFG="ignorertctime",1
+QSSLCFG: 2,4,2,"0X0005,0X0004,0X0035,0X002F,0X003D,0X000A","RAM:cacert.pem","RAM:client.pem","RAM:user_key.pem"
AT+CGACT=1,1
AT+QIACT
 AT+QMTOPEN=0,"**********.amazonaws.com",8883
+QMTOPEN: 0,-1
+PDP DEACT
AT+QMTOPEN?
AT+QNSTATUS
+QNSTATUS: 0
AT+QISTAT
STATE: PDP DEACT
AT+QNSTATUS
+QNSTATUS: 0
AT+CREG?
+CREG: 0,5
AT+QMTCONN=0,"gsm_test"
+CME ERROR: invalid parameter
Hi,I suggest you change the URL in double quotes to an ip domain name:
AT+QMTOPEN=0,“**********.amazonaws.com”,8883
Hello @vincent.ding-Q
I have tested your suggestion and the result is the same.
Is this firmware version compatible with MQTT commands? (MC90CAR01A04) Or should I update it? In this case could you give me further support?
I also noticed some issues with AT+CGACT=1,2 command.
It returns +CME ERROR: unknown error.
I have tested different contexts and the result is the same.
Regards
112.31.84.164:8306
This is our non-certificate MQTT server, I suggest you test it
The AT+CGACT issue was solved.
@herbert.pan-Q I have tested the code succesfully with your MQTT server:
Because of this, I think that the reason it doesn`t work with the AWS server may be the certificates. I have checked that my certificates work with MQTT.fx tool. So maybe I’m writing them incorrectly. This is the sequence:
My SSL cfg is the following:
Yes, I also think it’s the certificate. Please check it carefully
