Issue with RM502Q-GL never connect to internet
I order this module from Aliexpres, with Banana PI R4. then I tried both openwrt and Rooter GUI a ported 5G openwrt and none of that picking up LTE/5g Signla.
Each time I boot the system wait 2 mins then it disconnects the modem and sometimes gives error like " SIM locked No sim pin inserted" my sim has no pin lock also gives me another error which No IP address obtained !!
with all tires I did since I bought this module I never had connected to internet.
Kindly have a look to mode log.
Thu Jan 1 00:00:09 1970 : usb-modeswitch Delay for boot up
Sun Sep 29 18:18:14 2024 : ROOter Initialize Initializing Rooter
Sun Sep 29 18:18:15 2024 : usb-modeswitch Device 2-1.1
Sun Sep 29 18:18:16 2024 : usb-modeswitch Add : 2-1.1: Manufacturer=Quectel Product=RM502QGL_VA Serial=a4d1f6cc 2c7c 0800
Sun Sep 29 18:18:16 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:18:16 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sun Sep 29 18:18:16 2024 : usb-modeswitch 1 * Product=RM502QGL_VA 2c7c 0800
Sun Sep 29 18:18:16 2024 : usb-modeswitch 1 Found Modem at 2-1.1 in Cfg#= 1 from 1 available
Sun Sep 29 18:18:16 2024 : usb-modeswitch 1 * Device at 2-1.1 does not have a switch data file
Sun Sep 29 18:18:17 2024 : usb-modeswitch Ignoring Named Hub
Sun Sep 29 18:18:17 2024 : usb-modeswitch Ignoring Linux Hub
Sun Sep 29 18:18:26 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:18:26 2024 : usb-modeswitch 1 * Modem at 2-1.1 switched to : 2c7c:0800
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 7
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 1 option
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 2 option
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 3 option
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 4 cdc_ether
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 5 cdc_ether
Sun Sep 29 18:18:26 2024 : Protofind 2c7c/0800 Driver Name : 6
Sun Sep 29 18:18:26 2024 : usb-modeswitch 1 * ProtoFind returns : 5
Sun Sep 29 18:18:26 2024 : usb-modeswitch 1 Found Modem 1
Sun Sep 29 18:18:26 2024 : usb-modeswitch 1 Connecting a Hostless Modem or Phone
Sun Sep 29 18:18:26 2024 : Create Hostless Connection 1
Sun Sep 29 18:18:26 2024 : Create Hostless Connection 1 Hostless ID 2c7c:0800
Sun Sep 29 18:18:26 2024 : Create Hostless Connection 1 Modem 1 is a parent of ttyUSB0 ttyUSB1 ttyUSB2 ttyUSB3
Sun Sep 29 18:18:26 2024 : Create Hostless Connection 1 Modem Type 5
Sun Sep 29 18:18:26 2024 : Create Hostless Connection 1 Modem 1 ECM Comm Port : /dev/ttyUSB2
Sun Sep 29 18:18:26 2024 : PreConnect 1 Running PreConnect script
Sun Sep 29 18:18:42 2024 : usb-modeswitch Device 1-1.5
Sun Sep 29 18:18:42 2024 : usb-modeswitch Add : 1-1.5: Manufacturer=VIA_Labs,_Inc. Product=USB_Billboard_Device Serial=0000000000000001 2109 8822
Sun Sep 29 18:18:42 2024 : usb-modeswitch 2 *****************************************************************
Sun Sep 29 18:18:42 2024 : usb-modeswitch 2 * Start of Modem Detection and Connection Information
Sun Sep 29 18:18:42 2024 : usb-modeswitch 2 * Product=USB_Billboard_Device 2109 8822
Sun Sep 29 18:18:42 2024 : usb-modeswitch 2 Found Modem at 1-1.5 in Cfg#= 1 from 1 available
Sun Sep 29 18:18:42 2024 : usb-modeswitch 2 * Device at 1-1.5 does not have a switch data file
Sun Sep 29 18:18:47 2024 : Band Mask 1
Sun Sep 29 18:18:47 2024 : Band Mask 1 Modem PID : 0800
Sun Sep 29 18:18:47 2024 : Band Mask 1 Modem Model :
Sun Sep 29 18:18:48 2024 : Band Mask 1
Sun Sep 29 18:18:49 2024 : Band Mask 1
Sun Sep 29 18:18:49 2024 : Band Mask 1 Quectel Response : AT+QNWPREFCFG=“lte_band”
ERROR
Sun Sep 29 18:18:51 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nsa_nr5g_band:+QNWPREFCFG::nsa_nr5g_band:78:OK:
Sun Sep 29 18:18:52 2024 : usb-modeswitch 2 *****************************************************************
Sun Sep 29 18:18:52 2024 : usb-modeswitch 2 * Modem at 1-1.5 switched to : 2109:8822
Sun Sep 29 18:18:52 2024 : Protofind 2109/8822 Number Interfaces w/drivers : 1
Sun Sep 29 18:18:52 2024 : Protofind 2109/8822 Driver Name : 0
Sun Sep 29 18:18:52 2024 : usb-modeswitch 2 * ProtoFind returns : 0
Sun Sep 29 18:18:53 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nr5g_band:+QNWPREFCFG::nr5g_band:0:OK:
Sun Sep 29 18:18:56 2024 : Band Mask 1
Sun Sep 29 18:18:56 2024 : Band Mask 1 LTE Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:18:56 2024 : Band Mask 1 5G NSA Band Mask : 000000000000000000000000000000000000000000000000000020000000000000000000
Sun Sep 29 18:18:56 2024 : Band Mask 1 5G NA Band Mask : 0
Sun Sep 29 18:18:57 2024 : SimLock 1 Not Locked
Sun Sep 29 18:19:16 2024 : Get Profile 1 Modem 1 is Quectel RM502QGL
Sun Sep 29 18:19:16 2024 : Get Profile 1 Default Profile Used
Sun Sep 29 18:19:17 2024 : SimLock 1 Not Locked
Sun Sep 29 18:19:17 2024 : Create Hostless Connection 1 Profile for Modem 1 sets interface to WAN1
Sun Sep 29 18:19:17 2024 : Check Connection 1 Check Conn running
Sun Sep 29 18:19:17 2024 : Check Connection 1 7
Sun Sep 29 18:19:17 2024 : Create Hostless Connection 1 Modem 1 is using WAN1
Sun Sep 29 18:19:17 2024 : Create Hostless Connection 1 Checking Network Interface
Sun Sep 29 18:19:17 2024 : Create Hostless Connection 1 Modem 1 ECM Data Port : usb0
Sun Sep 29 18:19:17 2024 : Create Hostless Connection 1 Using Hostless Modem as a DNS relay
Sun Sep 29 18:19:22 2024 : TTL Settings 1 Deleting TTL/HL on interface usb0
Sun Sep 29 18:19:22 2024 : Create Hostless Connection 1 000000,jawalnet.com.sa,Default,1,0,ipv4
Sun Sep 29 18:19:22 2024 : Lock Provider Check ISP Lock
Sun Sep 29 18:19:25 2024 : Create Hostless Connection 1 PDP Type selected in the Connection Profile: “IP”, active: “IP”
Sun Sep 29 18:19:37 2024 : Check Connection 1 6
Sun Sep 29 18:19:57 2024 : Check Connection 1 5
Sun Sep 29 18:20:17 2024 : Check Connection 1 4
Sun Sep 29 18:20:28 2024 : Create Hostless Connection 1 Using jawalnet.com.sa
Sun Sep 29 18:20:37 2024 : Check Connection 1 3
Sun Sep 29 18:20:57 2024 : Check Connection 1 2
Sun Sep 29 18:21:17 2024 : Check Connection 1 1
Sun Sep 29 18:21:37 2024 : Check Connection 1 0
Sun Sep 29 18:21:57 2024 : Check Connection 1 Modem Restart
Sun Sep 29 18:23:20 2024 : Create Hostless Connection 1 Quectel Unsolicited Responses Disabled
Sun Sep 29 18:25:36 2024 : Modem Restart/Disconnect 1 Hard modem reset done
TIMEOUT ERROR
Sun Sep 29 18:26:31 2024 : ModeChange 1
TIMEOUT ERROR
Sun Sep 29 18:28:21 2024 : Create Hostless Connection 1 IP address(es) obtained:
Sun Sep 29 18:28:21 2024 : Create Hostless Connection 1 No IP Address
Sun Sep 29 18:28:21 2024 : Create Hostless Connection 1 Did not connect
I also tried the USB stick with no help. I don’t know if its firmware issue or not.
RM502QGLAAR05A03M4G_01.002.01.002
another errors come up “Can’t open /dev/ttyUSB2” when I change protocol mode or I select and deselect Bands.
Sun Sep 29 18:27:32 2024 : ROOter Initialize Initializing Rooter
Sun Sep 29 18:27:33 2024 : usb-modeswitch Device 2-1.1
Sun Sep 29 18:27:33 2024 : usb-modeswitch Add : 2-1.1: Manufacturer=Quectel Product=RM502QGL_VA Serial=a4d1f6cc 2c7c 0800
Sun Sep 29 18:27:33 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:27:33 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sun Sep 29 18:27:33 2024 : usb-modeswitch 1 * Product=RM502QGL_VA 2c7c 0800
Sun Sep 29 18:27:33 2024 : usb-modeswitch Ignoring Linux Hub
Sun Sep 29 18:27:33 2024 : usb-modeswitch Delay for previous modem
Sun Sep 29 18:27:33 2024 : usb-modeswitch 1 Found Modem at 2-1.1 in Cfg#= 1 from 1 available
Sun Sep 29 18:27:33 2024 : usb-modeswitch Ignoring Named Hub
Sun Sep 29 18:27:33 2024 : usb-modeswitch 1 * Device at 2-1.1 does not have a switch data file
Sun Sep 29 18:27:43 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:27:43 2024 : usb-modeswitch 1 * Modem at 2-1.1 switched to : 2c7c:0800
Sun Sep 29 18:27:43 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 7
Sun Sep 29 18:27:43 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sun Sep 29 18:27:43 2024 : Protofind 2c7c/0800 Driver Name : 1 option
Sun Sep 29 18:27:43 2024 : Protofind 2c7c/0800 Driver Name : 2 option
Sun Sep 29 18:27:43 2024 : Protofind 2c7c/0800 Driver Name : 3 option
Sun Sep 29 18:27:44 2024 : Protofind 2c7c/0800 Driver Name : 4 cdc_ether
Sun Sep 29 18:27:44 2024 : Protofind 2c7c/0800 Driver Name : 5 cdc_ether
Sun Sep 29 18:27:44 2024 : Protofind 2c7c/0800 Driver Name : 6
Sun Sep 29 18:27:44 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:27:44 2024 : usb-modeswitch 1 * ProtoFind returns : 5
Sun Sep 29 18:27:44 2024 : usb-modeswitch 1 Found Modem 1
Sun Sep 29 18:27:44 2024 : usb-modeswitch 1 Connecting a Hostless Modem or Phone
Sun Sep 29 18:27:44 2024 : Create Hostless Connection 1
Sun Sep 29 18:27:44 2024 : Create Hostless Connection 1 Hostless ID 2c7c:0800
Sun Sep 29 18:27:44 2024 : Create Hostless Connection 1 Modem 1 is a parent of ttyUSB0 ttyUSB1 ttyUSB2 ttyUSB3
Sun Sep 29 18:27:44 2024 : Create Hostless Connection 1 Modem Type 5
Sun Sep 29 18:27:44 2024 : Create Hostless Connection 1 Modem 1 ECM Comm Port : /dev/ttyUSB2
Sun Sep 29 18:27:44 2024 : PreConnect 1 Running PreConnect script
Sun Sep 29 18:27:58 2024 : usb-modeswitch Device 1-1.5
Sun Sep 29 18:27:58 2024 : usb-modeswitch Add : 1-1.5: Manufacturer=VIA_Labs,_Inc. Product=USB_Billboard_Device Serial=0000000000000001 2109 8822
Sun Sep 29 18:27:58 2024 : usb-modeswitch 2 *****************************************************************
Sun Sep 29 18:27:58 2024 : usb-modeswitch 2 * Start of Modem Detection and Connection Information
Sun Sep 29 18:27:58 2024 : usb-modeswitch 2 * Product=USB_Billboard_Device 2109 8822
Sun Sep 29 18:27:58 2024 : usb-modeswitch 2 Found Modem at 1-1.5 in Cfg#= 1 from 1 available
Sun Sep 29 18:27:58 2024 : usb-modeswitch 2 * Device at 1-1.5 does not have a switch data file
Sun Sep 29 18:28:01 2024 : Band Mask 1
Sun Sep 29 18:28:01 2024 : Band Mask 1 Modem PID : 0800
Sun Sep 29 18:28:01 2024 : Band Mask 1 Modem Model :
Sun Sep 29 18:28:08 2024 : usb-modeswitch 2 *****************************************************************
Sun Sep 29 18:28:08 2024 : usb-modeswitch 2 * Modem at 1-1.5 switched to : 2109:8822
Sun Sep 29 18:28:09 2024 : Protofind 2109/8822 Number Interfaces w/drivers : 1
Sun Sep 29 18:28:09 2024 : Protofind 2109/8822 Driver Name : 0
Sun Sep 29 18:28:09 2024 : usb-modeswitch 2 *****************************************************************
Sun Sep 29 18:28:09 2024 : usb-modeswitch 2 * ProtoFind returns : 0
Sun Sep 29 18:28:09 2024 : Band Mask 1
Sun Sep 29 18:28:09 2024 : Band Mask 1 Quectel Response :
Sun Sep 29 18:28:09 2024 : Band Mask 1 EM160/RM500
Sun Sep 29 18:28:09 2024 : Band Mask 1 LTE Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:09 2024 : Band Mask 1 5G NSA Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:09 2024 : Band Mask 1 5G NA Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:09 2024 : usb-modeswitch Remove 2-1.1
Sun Sep 29 18:28:09 2024 : SimLock 1 Locked/No Pin
Sun Sep 29 18:28:10 2024 : usb-modeswitch *****************************************************************
Sun Sep 29 18:28:10 2024 : usb-modeswitch * Remove : 2-1.1 : Modem 1
Sun Sep 29 18:28:10 2024 : usb-modeswitch * No Modems present
Sun Sep 29 18:28:12 2024 : usb-modeswitch Device 2-1.1
Sun Sep 29 18:28:12 2024 : usb-modeswitch Add : 2-1.1: Manufacturer=Quectel Product=RM502QGL_VA Serial=a4d1f6cc 2c7c 0800
Sun Sep 29 18:28:12 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:28:12 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sun Sep 29 18:28:12 2024 : usb-modeswitch 1 * Product=RM502QGL_VA 2c7c 0800
Sun Sep 29 18:28:12 2024 : usb-modeswitch 1 Found Modem at 2-1.1 in Cfg#= 1 from 1 available
Sun Sep 29 18:28:12 2024 : usb-modeswitch 1 * Device at 2-1.1 does not have a switch data file
Sun Sep 29 18:28:22 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 18:28:22 2024 : usb-modeswitch 1 * Modem at 2-1.1 switched to : 2c7c:0800
Sun Sep 29 18:28:22 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 1
Sun Sep 29 18:28:22 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sun Sep 29 18:28:22 2024 : usb-modeswitch 1 * ProtoFind returns : 11
Sun Sep 29 18:28:22 2024 : usb-modeswitch 1 Found Modem 1
Sun Sep 29 18:28:22 2024 : usb-modeswitch 1 Connecting a PPP Modem
Sun Sep 29 18:28:22 2024 : Create Connection 1 PPP Comm Port : /dev/ttyUSB2
Sun Sep 29 18:28:22 2024 : Create Connection 1 PPP Data Port : /dev/ttyUSB3
Sun Sep 29 18:28:22 2024 : PreConnect 1 Running PreConnect script
Sun Sep 29 18:28:22 2024 : Create Connection 1 Quectel Unsolicited Responses Disabled
Sun Sep 29 18:28:22 2024 : Band Mask 1
Sun Sep 29 18:28:22 2024 : Band Mask 1 Modem PID : 0800
Sun Sep 29 18:28:22 2024 : Band Mask 1 Modem Model : open
Sun Sep 29 18:28:22 2024 : Band Mask 1 Quectel Response : Can’t open device /dev/ttyUSB2.
Sun Sep 29 18:28:22 2024 : Band Mask 1 EM160/RM500
Sun Sep 29 18:28:23 2024 : Band Mask 1
Sun Sep 29 18:28:23 2024 : Band Mask 1 LTE Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:23 2024 : Band Mask 1 5G NSA Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:23 2024 : Band Mask 1 5G NA Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 18:28:23 2024 : Get Profile 1 Modem 1 is Can’t open device /dev/ttyUS Can’t open device /dev/ttyUS
Sun Sep 29 18:28:23 2024 : Get Profile 1 Default Profile Used
Sun Sep 29 18:28:23 2024 : SimLock 1 Locked/No Pin
Sun Sep 29 18:28:23 2024 : Create Connection 1 SIM Error
Last thing i come up with. I thought ISP is blocking the modem imei.
I change the modem IMEI to Iphone and I change TTL to 64 with hostless option.
Now it gives me IP address but no internet, the modem keep sending check connection 7 times then restart itself.
Sun Sep 29 18:58:43 2024 : TTL Settings 1 Setting HL 65 on interface usb0
Sun Sep 29 18:58:45 2024 : Create Hostless Connection 1 PDP Type selected in the Connection Profile: “”, active: “IPV4V6”
Sun Sep 29 18:58:47 2024 : Create Hostless Connection 1 Using JAWALNET.COM.SA
Sun Sep 29 18:58:51 2024 : Create Hostless Connection 1 Quectel Unsolicited Responses Disabled
Sun Sep 29 18:58:56 2024 : Create Hostless Connection 1 IP address(es) obtained: 10.169.42.151 2001:16A2:C086:6392:0000:0053:F074:3401
Sun Sep 29 18:58:56 2024 : Create Hostless Connection 1 Adding IPv6 dynamic interface
Sun Sep 29 18:58:56 2024 : Create Hostless Connection 1 Using Hostless Modem as a DNS relay
Sun Sep 29 18:58:58 2024 : Check Connection 1 6
Sun Sep 29 18:59:18 2024 : Check Connection 1 5
Sun Sep 29 18:59:38 2024 : Check Connection 1 4
Sun Sep 29 18:59:58 2024 : Check Connection 1 3
Sun Sep 29 19:00:18 2024 : Check Connection 1 2
Sun Sep 29 19:00:38 2024 : Check Connection 1 1
Sun Sep 29 19:00:58 2024 : Check Connection 1 0
Sun Sep 29 19:01:18 2024 : Check Connection 1 Modem Restart
Sun Sep 29 19:01:19 2024 : Modem Restart/Disconnect 1 Hard modem reset done
Sun Sep 29 19:01:19 2024 : usb-modeswitch Remove 2-1.1
Sun Sep 29 19:01:20 2024 : usb-modeswitch *****************************************************************
Sun Sep 29 19:01:20 2024 : usb-modeswitch * Remove : 2-1.1 : Modem 1
Sun Sep 29 19:01:20 2024 : usb-modeswitch * No Modems present
Sun Sep 29 19:01:37 2024 : usb-modeswitch Device 2-1.1
Sun Sep 29 19:01:37 2024 : usb-modeswitch Add : 2-1.1: Manufacturer=Quectel Product=RM502QGL_VA Serial=a4d1f6cc 2c7c 0800
Sun Sep 29 19:01:37 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 19:01:37 2024 : usb-modeswitch 1 * Start of Modem Detection and Connection Information
Sun Sep 29 19:01:37 2024 : usb-modeswitch 1 * Product=RM502QGL_VA 2c7c 0800
Sun Sep 29 19:01:37 2024 : usb-modeswitch 1 Found Modem at 2-1.1 in Cfg#= 1 from 1 available
Sun Sep 29 19:01:37 2024 : usb-modeswitch 1 * Device at 2-1.1 does not have a switch data file
Sun Sep 29 19:01:47 2024 : usb-modeswitch 1 *****************************************************************
Sun Sep 29 19:01:47 2024 : usb-modeswitch 1 * Modem at 2-1.1 switched to : 2c7c:0800
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Number Interfaces w/drivers : 7
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 0 option
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 1 option
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 2 option
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 3 option
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 4 cdc_ether
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 5 cdc_ether
Sun Sep 29 19:01:47 2024 : Protofind 2c7c/0800 Driver Name : 6
Sun Sep 29 19:01:47 2024 : usb-modeswitch 1 * ProtoFind returns : 5
Sun Sep 29 19:01:47 2024 : usb-modeswitch 1 Found Modem 1
Sun Sep 29 19:01:47 2024 : usb-modeswitch 1 Connecting a Hostless Modem or Phone
Sun Sep 29 19:01:47 2024 : Create Hostless Connection 1
Sun Sep 29 19:01:47 2024 : Create Hostless Connection 1 Hostless ID 2c7c:0800
Sun Sep 29 19:01:47 2024 : Create Hostless Connection 1 Modem 1 is a parent of ttyUSB0 ttyUSB1 ttyUSB2 ttyUSB3
Sun Sep 29 19:01:48 2024 : Create Hostless Connection 1
Sun Sep 29 19:01:48 2024 : Create Hostless Connection 1 Modem Type 5
Sun Sep 29 19:01:48 2024 : Create Hostless Connection 1 Modem 1 ECM Comm Port : /dev/ttyUSB2
Sun Sep 29 19:01:48 2024 : PreConnect 1 Running PreConnect script
Sun Sep 29 19:02:09 2024 : Band Mask 1
Sun Sep 29 19:02:09 2024 : Band Mask 1 Modem PID : 0800
Sun Sep 29 19:02:09 2024 : Band Mask 1 Modem Model :
Sun Sep 29 19:02:11 2024 : Band Mask 1
Sun Sep 29 19:02:11 2024 : Band Mask 1 Quectel Response : AT+CAT+QNWPREFCFG=“lte_band”
ERROR
Sun Sep 29 19:02:13 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nsa_nr5g_band:+QNWPREFCFG::nsa_nr5g_band:78:OK:
Sun Sep 29 19:02:15 2024 : Band Mask 1 EM160/RM500 AT+QNWPREFCFG=nr5g_band:+QNWPREFCFG::nr5g_band:0:OK:
Sun Sep 29 19:02:17 2024 : Band Mask 1
Sun Sep 29 19:02:17 2024 : Band Mask 1 LTE Band Mask : 000000000000000000000000000000000000000000000000000000000000000000000000
Sun Sep 29 19:02:17 2024 : Band Mask 1 5G NSA Band Mask : 000000000000000000000000000000000000000000000000000020000000000000000000
Sun Sep 29 19:02:17 2024 : Band Mask 1 5G NA Band Mask : 0
Sun Sep 29 19:02:19 2024 : SimLock 1 Not Locked
Sun Sep 29 19:02:38 2024 : Get Profile 1 Modem 1 is Quectel RM502QGL
Sun Sep 29 19:02:38 2024 : Get Profile 1 Default Profile Used
Sun Sep 29 19:02:39 2024 : SimLock 1 Not Locked
Sun Sep 29 19:02:39 2024 : Create Hostless Connection 1 Profile for Modem 1 sets interface to WAN1
Sun Sep 29 19:02:39 2024 : Check Connection 1 7
Sun Sep 29 19:02:39 2024 : Create Hostless Connection 1 Modem 1 is using WAN1
Sun Sep 29 19:02:39 2024 : Create Hostless Connection 1 Checking Network Interface
Sun Sep 29 19:02:39 2024 : Create Hostless Connection 1 Modem 1 ECM Data Port : usb0
Sun Sep 29 19:02:39 2024 : Create Hostless Connection 1 Using Hostless Modem as a DNS relay
Sun Sep 29 19:02:44 2024 : TTL Settings 1 Checking TTL
Sun Sep 29 19:02:44 2024 : TTL Settings 1 Setting TTL 65 on interface usb0
Sun Sep 29 19:02:44 2024 : Create Hostless Connection 1 000000,XXX.XXX.XXX,Default,1,0,ipv4v6
Sun Sep 29 19:02:44 2024 : TTL Settings 1 Checking HL
Sun Sep 29 19:02:44 2024 : TTL Settings 1 Setting HL 65 on interface usb0
Sun Sep 29 19:02:44 2024 : Lock Provider Check ISP Lock
Sun Sep 29 19:02:47 2024 : Create Hostless Connection 1 PDP Type selected in the Connection Profile: “”, active: “IPV4V6”
Sun Sep 29 19:02:48 2024 : Create Hostless Connection 1 Using JAWALNET.COM.SA
Sun Sep 29 19:02:52 2024 : Create Hostless Connection 1 Quectel Unsolicited Responses Disabled
Sun Sep 29 19:02:58 2024 : Create Hostless Connection 1 IP address(es) obtained: 10.XX.7X.1X 2001:16A2:C08A:514D:0000:0053:F074:3F01
Sun Sep 29 19:02:58 2024 : Create Hostless Connection 1 Adding IPv6 dynamic interface
Sun Sep 29 19:02:58 2024 : Create Hostless Connection 1 Using Hostless Modem as a DNS relay
Sun Sep 29 19:02:59 2024 : Check Connection 1 6
Dear @suntop
You can try to use QUectel-CM to dail up.
I will sent to you via Message, please check.
(post deleted by author)
@silvia
It didn’t work either, but I resolved this issue after upgrading my Modem version to RM502QGLAAR11A02M4G_01.200.01.200. Before, the modem only used ECM, which ended up with a lot of issues, including the modem restart and locking my SIM. Now, after the upgrade, the mode can switch between protocols easily, and it has 3 tubs.
For anyone who has a similar issue refer to this post here helped me a lothttps://eko.one.pl/forum/viewtopic.php?id=24137
