Issue with Quectel RM520N-GL on Qualcomm QCS-6490 (Yocto) – Unable to Make Calls / Send SMS
I am using the Quectel RM520N-GL module on a Qualcomm QCS-6490 Yocto image. The module is detected and verified with lsusb, and /dev/ttyUSB* devices are created correctly.
System details:
Linux qcs6490aom2721a1 6.6.52-yl01301-ga97804e47e26 #1 SMP PREEMPT Wed Apr 2 14:43:28 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
lsusb output:
Bus 003 Device 003: ID 2c7c:0801 Quectel Wireless Solutions Co., Ltd. RM520N-GL
Bus 003 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Created devices:
root@qcs6490aom2721a1:~# ls /dev/ttyUSB*
/dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3
WWAN interface:
wwan0 Link encap:Ethernet HWaddr EA:A9:EA:93:58:3C
inet addr:169.254.190.247 Bcast:169.254.255.255 Mask:255.255.0.0
inet6 addr: fe80::b7ba:edf0:6176:dd98/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
AT command tests (via /dev/ttyUSB2):
microcom -s 115200 /dev/ttyUSB2
AATT
ATD+9173XXXXXXXX;
ATD+9173XXXXXXXX;
NO CARRIER
AT+QCFG=“ims”
AT+QCFG=“ims”
+QCFG: “ims”,0,0
AT+CMGF=1
AT+CMGF=1
AT+CMGS=“+9173XXXXXXX”
HHeelllloo ffrroomm QQuueecctteell
+CMS ERROR: 350
AT+CREG?
AT+CREG?
+CREG: 0,0
AT+CGREG?
AT+CGREG?
+CGREG: 0,0
AT+COPS?
AT+COPS?
+COPS: 0
AT+CPIN?AT+CPIN?
+CPIN: READY
AT+CSQ
AT+CSQ
+CSQ: 14,99
AT+QCFG=“nwscanmode”,0,1AT+QCFG=“nwscanmode”,0,1
ERROR
AT+QCFG=“?”
AT+QCFG=“?”
ERROR
Issue:
While trying to make a call or send an SMS, I get errors (NO CARRIER or +CMS ERROR: 350).
The SIM is detected (+CPIN: READY), but registration fails (+CREG: 0,0 and +CGREG: 0,0).
Could anyone guide me on how to proceed further with network registration and resolving this issue?
Thanks in advance!
It is not registerred in LTE or NR at all.
Hi Wang
Thanks for the reply. I understand that +CGREG: 0,0 means the module is not registered on LTE/NR.
I tried running the following command to force LTE/NR:
AT+QCFG=“nwscanmode”,3,1
But I am not getting any response (not even OK or ERROR).
Could this be related to firmware version or SIM/operator compatibility?
Are there other AT commands I should use to troubleshoot why the module is not registering on LTE/NR
Extra info:
SIM is detected: +CPIN: READY
Signal is available: +CSQ: 14,99
But registration fails: +CREG: 0,0, +CGREG: 0,0
Any guidance on the correct scan mode settings or next steps for registration would be really helpful.
Thanks in advance!
I am not sure whether you have locked the mode or the band.
Or it is just the problem of the SIM card.
AT+QNWPREFCFG=“mode_pref”
AT+QENG=“servingcell”
ERROR
ERROR
Hi Wang,
Thank you for your quick support. I tried using the echo command and got the following response:
It seems the modem is trying to connect to the network but cannot.
Could you advise what I should do next?
The SIM is inserted but not yet registered on the network. Do I need to register the SIM with the network manually?
The signal appears to be very weak, or there’s no coverage. I am not connected to the antenna—could that be causing the issue?
Here are the commands I ran and their outputs:
root@qcs6490aom2721a1:~#echo -e ‘AT+QNWPREFCFG=“mode_pref”\r’ > /dev/ttyUSB2
root@qcs6490aom2721a1:~# cat /dev/ttyUSB2
+QNWPREFCFG: “mode_pref”,AUTO
^C
root@qcs6490aom2721a1:~# echo -e ‘AT+QENG=“servingcell”\r’ > /dev/ttyUSB2
+QENG: “servingcell”,“SEARCH”
I would appreciate any guidance on the next steps.
Thanks in advance!
Can you try another SIM card?
+QENG: “servingcell”,“SEARCH” means that it is still searching and not registerred.
Are the four antenna connected?
