I am trying to install use quectel-cm instead of modemmanager on an ubuntu 20 machine. When when I run the quectel-cm command, I am not able to connect. I will attach a video to show the current state. Any help would be gratefull.
Hi,i think because your device is disconnected,you need to reconnect manually if you’re not using external power
@Jamshaid_Amjad When you mean device, are you referring to the quectel modem?
Dear @Stevedan
Please execute: lsusb -t and share the response to us.
And uninstall modemmanager.
Please provide the info:
dmesg log
and
cat /sys/kernel/debug/usb/devices
I was able to solve it. It seem i was setting the usbnet wrong. It had to be 0 not 3. After that and resseting modem with cfun, it worked.
