Issue: Quectel L86 loses ephemeris data after power cycling (V_BCKP connected)
I am using a Quectel L86 GNSS module in a design where the main power (VCC) is switched on/off using a MOSFET, while the backup supply (V_BCKP) is permanently connected to a 3.3 V rail.
The intended behavior is that when VCC is turned off, the module should retain:
  • RTC time
  • last known position
  • ephemeris (valid for hot start)
The main goal is to achieve a hot start (1–2 seconds) when the module is powered again.
How the system works
  • VCC is turned on for about 10 seconds so the module can obtain a fix.
  • After that, VCC is switched off via MOSFET (module fully powered down).
  • V_BCKP remains powered at all times.
  • After some time, VCC is turned on again.
However, I am seeing the following behavior:
  • RTC survives (correct time is output immediately after boot).
  • But ephemeris data are lost, causing a warm/cold start (10–20 seconds) instead of a hot start.
Example logs
After power-up — RMC shows no fix (V)
$GNRMC,221617.189,V,,,,,0.20,199.53,031225,,,N,V*2A
$GNGGA,221617.189,,,,,0,0,,,M,,M,,*57
Over several seconds, it continues like this:
$GNRMC,221618.167,V,,,,,0.26,207.89,031225,,,N,V*20
$GNRMC,221619.165,V,,,,,0.36,231.23,031225,,,N,V*27
$GNRMC,221620.165,V,,,,,0.13,245.25,031225,,,N,V*2F
The module outputs the correct UTC time immediately (RTC is fine), but position fields are empty and fix status is V, which means ephemeris are missing and the receiver needs to download them again.
Expected hot start (which I get only when VCC is never removed)
When VCC is always powered (no power cycling), I get:
$GNRMC,221538.000,A,5107.4687,N,01703.0454,E,...
Fix is obtained in 1–2 seconds, meaning ephemeris are present.
What I already tried
:check_mark: Added backup capacitors on V_BCKP:
  • 4.7 µF ceramic capacitor (X5R)
  • 0.1 µF (100 nF) placed very close to the V_BCKP pin
This matches Quectel’s hardware design recommendations.
:check_mark: Verified that V_BCKP is always powered
It stays at 3.3 V even when VCC is off.
:check_mark: RTC does not reset
The time reported immediately after start is correct.
Problem summary
Even though V_BCKP is powered and RTC survives, ephemeris are still lost whenever VCC is switched off via MOSFET.
Only when VCC remains continuously powered do I get a true hot start.
This strongly suggests:
  • A short voltage drop or glitch on V_BCKP during VCC power-down
  • Or current backflow from VCC into V_BCKP
  • Or a reset condition affecting the GNSS SRAM even though RTC survives
What else can I check?
Hi @Adam_Sz
Thank you for reaching out
In order to support your issue i would need to know some information
  1. What is the firmware version for L86:
    You can obtain the version by sending command $PQVERNO,R*3F
  2. What is the cut off period of Vcc during your testing:
  3. Can you send me the NMEA Log file of the whole process? it can be found in LogFile directory
  4. Try using the command method to enter backup mode, send command $PMTK225,4*2F. To exit the backup mode, pull FORCE_ON to high. Let me know if the results are the same.
  5. Make sure the V_BCKP is powered on before the VCC during start up as shown in the diagram
  6. Can you send me the schematic design of your hardware? you can send me through email.
Looking forward to your responds
Best regards
Hi, I have exactly the same problem with LC29H. I already even tried removing RX and TX lines completely and still all I am getting is RTC.
So it looks like something invalidates the ephemeris.
I am using below LC29H board hooked up to ESP32C3 board show below as well:
RX and TX are connected directly and power 3.3V and GND are also taken directly from the ESP board.
My scenario is that I want hot start if/when USB cable gets disconnected from ESP32 for up to few minutes. Right now I can not even survive like 1 second of powerdown
LC29H is set to defaults and I do not send anything to it at all.
Hi @Mariusz_D
The circuit wiring is correct for basic operation, but the lack of backup power retention is the main reason the LC29H cannot perform hot start after USB disconnection. If only VCC (which from ESP32) is supplied and it drops when USB is disconnected, the module loses its aiding data immediately and this is expected.
Adding a backup battery/supercap and optionally injecting aiding data will allow the module to survive short power losses and achieve the intended hot start behavior.
Recommendation:
  • Add backup power: Connect a coin cell or supercapacitor to the LC29H’s V_BCKP pin so it can retain ephemeris and RTC during short outages.
  • Inject aiding data: Use AGNSS/EPO files to accelerate hot start if backup retention is limited.
Best regards,
Hi @mohamad.firdaus ,
but there is a coin battery and it is fully charged. Also I am retaining RTC clock just fine. But looks like I am loosing just the ephemeris.
What could be causing such a situation? RTC clock stays OK but ephemeris are lost.
Hi @Mariusz_D can you check the voltage reading on the V_BCKP pin when the USB disconnected? It should be on Pin 22.
You may check further the hardware design documentation as in this link: https://www.quectel.com/download/quectel_lc29h_series_hardware_design_v1-4/
Please also share your test setup photos for better clarity and understanding.
Best regards.
