The default output rate is the fix interval ,it will use too much data.
Can I change the rate?
Hi @ZPL,
RTCM output rate as it is fixed at 1 Hz when the module is in Base Station mode.
The flexibility to modify RTCM output rates is a feature of higher-tier modules like the LG29xP and LGx80P series , rather than the LC29H.
Also, please take note that LC29H(BS) is already EOL. If you wish to look into other GNSS module, please contact our local sales: xuzeng.li@quectel.com spark.zhang@quectel.com
