I have an EG25G with serial number:
EG25GGBR07A07M2G
Is GPS supported in my module? I can’t get a fix when I send GNSS commands and keep getting +CME ERROR: 516.
EG25GGBR07A07M2G
Yes,this module can support GPS. If you can’t get a fix, please check whether you connect the correct GPS antenna, and place it at outdoor environment, and you can change the GPS antenna and test environment to have a try. Thanks!
