could you please provide instructions to enable SUPL functionality using AT commands?
Hi @AndreySV
AT+QGPSCFG=“suplver”[,<SUPL_version>]
@lyman-Q thanks for the answer.
We are trying to enable SUPL functionality using following steps
AT+QGPSEND
AT+QGPSCFG="lbsapn",16,1,"INTERNET.PROVIDER.COM"
AT+QGPSCFG="suplver",2
AT+QGPSSUPLURL="supl.google.com:7276"
AT+QGPSCFG="plane",0
AT+QGPS=1,2
INTERNET.PROVIDER.COM is the same APN used for mobile data.
We’ve tried to replace “supl.google.com:7276” with our public server “EXTERNAL_IP:7276” to check whether EG25-G tries to connect to supl server. But there was no any connection to our server. Could you please help, what we are missing to enable SUPL functionality?
Hi @AndreySV
Can other devices connect to this server? EXTERNAL_IP:7276
I can connect to this server from the device through EG25-G over 4G using following command
nc EXTERNAL_IP 7276
And I see successful connection to the server, but I don’t see any connection attempt, when I try to setup SUPL.
Are there any conditions (activate context, visible satellites, …) to start SUPL connection?
Are default settings ok? Should I change ‘AT+QGPSCFG=“agpsposmode”’ or defaults are good?
Similar question: Determine if SUPL is working on EG25-G - #5 by Raphael-Q
To initiate connection AT+QGPS=2 should be used.
Is it possible to reset “lbsapn” setting?
AT+QGPSCFG="lbsapn"
