Install RM530N-GL_5G_HAT with PCIe under Ubuntu 24.04
Dear,
I have Pi5 with RM530N-GL_5G_HAT under the Ubuntu 24.04, currently i connect RM530N-GL with both PCIe and USB, can recognize the module under the usb, below is the command “lsusb” result.
lab@pi5:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2c7c:0801 Quectel Wireless Solutions Co., Ltd. RM530N-GL
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Also add the dtparam=pciex1 in the file-“/boot/firmware/config.txt”
I want to use that with PCIe, then can reduce the USB cable and port, how I can transfer the connect to PCIe, and dial that with 5G?
Could someone can help on that? Thanks
Dear @william8709
I have sent a document to you via Message, please refer to it.
Please try
make ARCH=arm64
