Install EC25 QMI WWAN driver in Kernel 4.9.201-terga
Hi all.
I am trying to use my Jetson Nano to connect to the internet through the EC25 LTE module. I have configure the USB driver and my Jetson can communicate with the EC25 module through AT command. However, I have no idea how to install the QMI WWAN driver. May I know if there is any guidance for this installation?
Thanks in advanced!
Hi ,
I has been emailed to you.
Thanks for reply. I found this datasheet and I followed the step until the step we need to build the kernel. We found difficulty to get the command to build the kernel for Jetson Nano. Also, may I know if it is compulsory to compile the kernel to install the driver?
Thank you. I look forward to hearing more from you.
Hi, can I receive a copy of the instructions too.
Hi, can I receive a copy of the instructions too?
can i get someguidance to install qmi_wwan driver in jetson
Ok, I will send user gudie of the qmi_wwan driver to you via email.
Hi there, may I request for a copy of the user guide to install qmi_wwan and get the modems working on a Jetson please? Thanks!
Hi there, could I have a copy of the instructions and files sent to my email too? Thanks in advance!
@Traser Ok, I will send user gudie of the qmi_wwan driver and file to you via email.
Hi can u send me guide also
