Instability in staying camped only on the home network
Hi.
I’m starting a project with 5G and I still have little experience in this telecommunications area. In my lab I have a Quectel RM520N-GL board and a USRP B210 board. Everything is connected and working relatively well. That is, my 5G modem is camped on my 5G test network (MCC = 001 and MNC = 01) and is registered. See:
+QENG: “servingcell”,“NOCONN”,“NR5G-SA”,“TDD”,001,01,000000E00,0,1,641280,78,6,-84,-11,22,1,-
However, if I move the gNB a few centimeters away from the modem, the RM520N will camp on a carrier operator’s network. So the modem’s connection to the 5G network is very sensitive. In a stable situation, the gNB and 5G modem are only 1 meter apart.
What can cause this instability? What should I check on the modem or on the gNB?
Notes: my 5G modem has 3 antennas, but there is room to connect one more. With 3 antennas, could I have problems registering on the lab network? Does that make sense? Also, my modem has a USB cable with 2 plugs to connect to my computer. I connected only one of the plugs to the machine where I run AT commands. The other plug (not connected) is for extra power to the 5G modem? Should I connect it as well? Could not connecting it cause instability of the link with the gNB?
On my USRP B210 I connected only one antenna to TX/RX. I did not connect RX2. Should I connect another antenna to RX2?
Thank you very much for any tips.
Best regards.
Deviating from the questions you’ve asked, I’ll just mention that you can lock the modem to your network with the AT command: AT+COPS=1,2,"00101"
Hi.
Thank you for your reply. I had tried that last Friday. But this command returns the response “+CME ERROR: 30” 99% of the time. So I also tried the other two formats of this command:
0 → Long format alphanumeric up to 16 characters.
1 → Short format alphanumeric .
That is:
AT+COPS=1,0,“Long format alphanumeric ”
AT+COPS=1,1,“Short format alphanumeric ”
These last two commands return OK as a response, but they have no effect on the RM520N-GL module.
For these reasons, I suspected a problem with signal strength or antenna positioning.
The “soft” lock option AT+COPS=4,2,"00101" is also worth a try.
