While going through the openCPU features I came across few queries which are as follows:
Status LEd with openCPU does not glow by default on PwrKey On. How to control it programmatically? Can it be by default work in teh same way as it works with AT Command firmware?
In audio_demo.c, external codec read is failing everytime. I have connected and tried both the Audio codec module in EVB kit. but still I’m getting Read failed. [ql_audio][ql_switch_ext_codec, 849] read codec failed
Is there any way to test analog audio output on EVB kit? I can see that all the audio output/input are interfaced to the Audio codec and non are connected to analog audio output/input.
Thanks and regards
Abhishek
