I have a device in the UK which is using the Quectel BG95-M3 module. I’m currently seeing a strange default value for the date/timestamp when monitoring the cellular debug.
The same device in the US seems to report the correct date/timestamp. Is there some configuration change I need to make on the device while it’s in the UK?
Thanks.
Is NITZ enabled?
What does AT+CTZU? return?
Thanks for your reply.
AT+CTZU?
+CTZU: 1
Not sure on the status of NITZ.
I tried AT+NITZ? but that returns an error.
Regards.
That says NITZ is enabled. I can only assume that your UK provider is not broadcasting time and timezone info on LTE Cat M1.
Ok, that makes sense. Thanks for the feedback
