Import error for QuecPython modue "lwm2m" on EC200U-EU AA
I am using a Quectel EC200U-EU AA board and wanted to setup a LwM2M client utilizing the "example_lwm2m.py2 as basis to start up with.
Unfortunately this doesn’t work, because the import of the module “lwm2m” creates an error and it seems that it is not available in the FW of my chip.
Could you tell/provide me the FW which supports the lwm2m module.
Thanks a lot in advance!
I still need support in this matter.
Anyone from Quectel who might help me here.
Best regards
Frank
hello
May I ask if you would be willing to fill out the requirement evaluation form? We can confirm which additional features you still need, so that we can provide a suitable firmware for you.
Quectel_QuecPython_Customer_Requirement_Questionnaire_V5.2@_FY250724xlsx-Overseas.zip (72.4 KB)
Hello I neede the FW as it is, plus support of the LwM2M protocol resp. the corresponding API enabled in the FW. Pls. the the screenshot I’ve provided earlier. Thanks in advance.
hi fnk
I’ve checked internally: if LWM2M support is required, a customized version will be necessary.
Could you kindly help fill out the table above? Once we confirm the specific features you need, I’ll have the internal team conduct an evaluation.
