I'm using the BG95-M3-ZERO, but when I try to connect via QCOM, there's no response from the COM port
Even after successfully applying the firmware QPY_OCPU_V0002_BG95M3_FW, there’s still no response from the COM port in QCOM. Also, when I try to use Thonny, the port doesn’t show up at all. What could be the reason for this?
hi
May I ask if you have updated to the latest driver? I suggest that you can update to the latest driver and download the latest firmware for testing.
Please download the firmware and drivers from the link below.
Resources Download | QuecDevZone
