Hi WizlO,
i have tried your program. i got successful response even the slave address is invalid. can you please suggest me to sort it out as soon as possible. i did connect RI as SCL and DCD as SDA.
here i copied my test program kindly go through it.
#include “custom_feature_def.h”
#include “ql_type.h”
#include “ql_stdlib.h”
#include “ql_uart.h”
#include “ril.h”
#include “ql_error.h”
#include “ql_iic.h”
#include “ql_gpio.h”
#include <stdint.h>
#include <stddef.h>
#define I2C_SlaveAddr 0x55
//#define I2C_WriteSlaveAddr 0xEC//1110 1100
#define I2C_ReadSlaveAddr 0x77//1110 1101
#define I2C_RECVBUF_LENGTH 8
#define I2C_SENDBUF_LENGTH 8
#define READ_BUFFER_LENGTH 1024
u8 I2C_RecvBuf[I2C_RECVBUF_LENGTH];
u8 I2C_SendBuf[I2C_SENDBUF_LENGTH] ={0xF5};
static u8 m_buffer[100];
static u8 m_Read_Buffer[READ_BUFFER_LENGTH];
char DBG_BUFFER[256];
#define DBG_PORT UART_PORT0
#define DBG(FORMAT, …)
Ql_memset(DBG_BUFFER, 0, sizeof(DBG_BUFFER));
Ql_sprintf(DBG_BUFFER, FORMAT, ##VA_ARGS);
Ql_UART_Write(DBG_PORT, (u8 *)DBG_BUFFER, Ql_strlen(DBG_BUFFER));
void uart_callback(Enum_SerialPort port, Enum_UARTEventType msg, bool level, void *customizedPara)
void proc_main_task(s32 taskId)
s32 ret;
ST_MSG msg;
Ql_UART_Register(DBG_PORT, uart_callback, NULL);
Ql_UART_Open(DBG_PORT, 115200, FC_NONE);
// u8 write_buffer[4]={0x10,0x02,0x50,0x0a};
// u8 read_buffer[6]={0x14,0x22,0x33,0x44,0x55,0x66};
DBG(“BEGIN\n”);
while (1)
Ql_OS_GetMessage(&msg);
switch (msg.message)
case MSG_ID_RIL_READY:
Ql_RIL_Initialize();
DBG(“Ril Ready\n”);
u8 write_buffer=0xF5;
u8 registerAdrr[2]={0x01,0x45};
//IIC Initialization
ret = Ql_IIC_Init(0,PINNAME_RI,PINNAME_DCD,1);
if(ret < 0)
DBG("\r\n<--Failed!! Ql_IIC_Init channel 1 fail ret=%d-->\r\n",ret);
DBG("\r\n<--pins(%d & %d) Ql_IIC_Init channel 1 ret=%d-->\r\n",PINNAME_RI,PINNAME_DCD,ret);
//IIC Config
ret = Ql_IIC_Config(0,TRUE, I2C_SlaveAddr,I2C_FREQUENCY_400K);
if(ret < 0)
DBG("\r\n<--Failed !!Ql_IIC_Config channel 1 fail ret=%d-->\r\n",ret);
DBG("\r\n<--Ql_IIC_Config channel 1 ret=%d-->\r\n",ret);
while(1){
ret = Ql_IIC_Write(0,I2C_SlaveAddr,&write_buffer,sizeof(write_buffer));
if(ret < 0)
DBG("\r\n<--Failed !! Ql_IIC_Write Channel 1 fail ret=%d-->\r\n",ret);
DBG("\r\n<--Channel 1 Ql_IIC_Write ret=%d-->\r\n",ret);
Ql_Sleep(200);
ret=Ql_IIC_Read(0,I2C_SlaveAddr,I2C_RecvBuf,2);
if(ret > 0){
DBG("Read Succeeded:%d\n",ret);
for(int i=0;i<2;i++){
DBG("Read : %d\t",I2C_RecvBuf[i]);
// ret=Ql_IIC_Write(1, I2C_SlaveAddr,write_buffer,2);
// if(ret > 0){
// DBG("Write Succeeded :%d\n",ret);
// // DBG("Read:%d\n",ret);
// ret=Ql_IIC_Read(1, I2C_SlaveAddr, read_buffer, sizeof(read_buffer));
// if(ret > 0){
// DBG("Read Succeeded:%d %d\n",ret,read_buffer[0],read_buffer[1]);
// ret=Ql_IIC_Write_Read(1, 0x77, registerAdrr, sizeof(registerAdrr),read_buffer, sizeof(read_buffer));
// if(ret > 0){
// DBG("write & Read Succeeded:%d\n",ret);
// for(int i=0;i<sizeof(read_buffer);i++){
// DBG("Read : %d\t",read_buffer[i]);
//IIC Write
ret = Ql_IIC_Write(1,I2C_SlaveAddr,(u8*)I2C_SendBuf,2);
if(ret < 0)
DBG("\r\n<--Failed !! Ql_IIC_Write channel 0 fail ret=%d-->\r\n",ret);
DBG("\r\n<--channel 1 Ql_IIC_Write ret=%d-->\r\n",ret);
//IIC read
ret = Ql_IIC_Read(1, I2C_ReadSlaveAddr, I2C_RecvBuf, 2); //read data
if(ret < 0)
DBG("\r\n<--Failed !! Ql_IIC_Read channel 1 fail ret=%d-->\r\n",ret);
DBG("\r\nLength : %d Read_buffer[0]=(%d) Read_buffer[1]=(%d) Read_buffer[2]=(%d) Read_buffer[3]=(%d) \r\n",ret,I2C_RecvBuf[0],I2C_RecvBuf[1],I2C_RecvBuf[2],I2C_RecvBuf[3]);
Ql_IIC_Uninit(1);
ret=Ql_GPIO_GetLevel(PINNAME_RI);
DBG("RI pin voltage level:%d\n",ret);
ret=Ql_GPIO_GetLevel(PINNAME_DCD);
DBG("DCD pin voltage level:%d\n",ret);
break;
Hmdra
