I want to upload a file to BG96
I don’t know how to upload a file to BG96.
We are currently testing with Arduino+Arduino NB-IoT shield+quectelBG96 configuration.
Arduino NB-IoT shield is from the following URL.
The third photo from the top is the overall composition photo.
https://www.robotshop.com/jp/ja/dragino-nb-iot-shield-arduino-quectel-bg96.html
I want to access AWS Iot with this configuration and send data.
To send data to AWS, you need to set up a certificate.
Therefore, in BG96, I think that the path of the certificate file is specified by the AT command as follows.
AT+QSSLCFG=“cacert”,1,“ufs:cacert.pem”
AT+QSSLCFG=“clientcert”,1,“ufs:clientcert.pem”
AT+QSSLCFG=“clientkey”,1,“ufs:clientkey.pem”
I think you need to upload the certificate file to UFS before you can specify the path.
I think I will upload using the AT+QFUPL command.
However, uploads did not work well in the current configuration.
How do I upload a certificate to UFS in my current Arduino+Arduino NB-IoT shield+quectelBG96 configuration?
yes you can upload file via AT+QFUPL ,
another way , you can upload via QPST – eFS explorer tools (from qualcomm0 via file system , copy your certificate to UFS directly
pls kindly down load QPST tools from the below link:
https://cnquectel-my.sharepoint.com/:f:/g/personal/america-fae_quectel_com/EmuR9cKm_7FNqtsO37DOVw8Bv-MI-8k6gq3UDLNpR1-WAg?e=pVmxCI
hi, I have met the same problem. I have used AT+QFUPL but no luck, please help
