I want m66 AT commands for mqtt
** List item*Quectel_GSM_MQTT_Application_Note_V1.2©.pdf (519.3 KB)
Dear swathi,
please find the attached Quectel_GSM_MQTT_Application_Note_V1.2©, if you have any questions please do not hesitate to contact us, thanks
Thank you for sending document,
When I send ATQMTCFG in m66 module it is showing CME ERROR
Dear Swathi,
It is better to provide the test log which contains the error information. Thanks!
It is displaying CME ERROR 100
ATQMTCFG
+CME ERROR: 100
it is showing error
Dear Swathi,
Please provide your whole test log, not just the error information, i need to know what paramaters you have set. Thanks!
By the way, you also can check the document of the MQTT application note to confirm whether you have enter into the wrong parameters. Thanks!
Thank you for response, i am using 2BT version i came to know it will not support mqtt commands.
Hello sir,
I have updated my system to 64 bit Windows 10 and having older SDK, and I am seeking for the updated SDK for Quectel M10F module.
You are requested to provide me the updated SDK.
Thanks and Best Regards
Dear Ketan,
Please note that M10F module already EOL, we will not update the SDK and firmware. Please check the following EOL notification. Thanks!
Quectel_EOL_2020031001_M10&GC10_EOL_Notification.pdf (655.2 KB)
The following is the last updated firmware and SDK. If you need, i can send it to you. Thanks!
I need the M10 SDK and Firmware
