Hello
I need the bootloader file -Quectel SC20-CE
I would be grateful if you could send it to me./
HI,
We can provide Android 7 firmware to you,
For SC20CE, one file is SC20CEPSR06, one file is SC20CEPQR06, can you help confirm which one is needed for you, you can share the full OC of the module for checking.
Thanks.
HI,
I can’t find the firmware for this OC at present.
I want to confirm when did you get this module?
I received it in 2020. Are there other ways?
We are having holiday, will confirm it next week.
Hello, can you help me with the above question?![]()
HI
Can you help confirm which Android version is used the module?
Thanks.
Android module 5.1.1
I can’t find the suitable firmware for this OC.
If your module can boot, you can check the firmware version in Settings and confirm which version is used.
Thanks.
