I need Linux usb driver and udev rules for RG200U-CN mini pcie module as with default kernel 6.1.55 lsusb down not show Quectel modem
Show the output of cat /sys/kernel/debug/usb/devices
No pictures please.
It is because the hwdb do not support the RG200U, but it doesnot matter.
There is no such udev rules.
Please check
ls /sys/bus/usb/drivers/
ls /lib/modules/`uname -r`/kernel/drivers/usb/serial/
ls /lib/modules/`uname -r`/kernel/drivers/net/usb/
Please follow the
https://www.quectel.com/download/quectel_umts_lte_5g_linux_usb_driver_user_guide_v3-2/
$ sudo cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 6.01
S: Manufacturer=Linux 6.1.55-hardened1 xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=xhci-hcd.1.auto
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 6.01
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
S: SerialNumber=xhci-hcd.2.auto
T: Bus=03 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=02 MxPS=64 #Cfgs= 1
P: Vendor=0424 ProdID=2514 Rev= b.b3
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 2mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=01 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
I:* If#= 0 Alt= 1 #EPs= 1 Cls=09(hub ) Sub=00 Prot=02 Driver=hub
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
$ ls /sys/bus/usb/drivers
asix ax88179_178a cdc_ether cdc_ncmcdc_subset cdc_wdm ch341 hub option qmi_wwan r8152 r8153_ecm rndis_host spi_ft232h uas usb usb_ehset_test usbfs usbhid usbserial_generic usb_serial_simple usb-storage
$ ls /sys/bus/usb/driversrun/current-system/kernel-modules/lib/modules/6.1.55-hardened1/kernel/drivers/net/usb
cdc_eem.ko.xz cdc_mbim.ko.xz dm9601.ko.xz huawei_cdc_ncm.ko.xz lan78xx.ko.xz mcs7830.ko.xz net1080.ko.xzpegasus.ko.xz plusb.ko.xz rtl8150.ko.xz smsc75xx.ko.xz smsc95xx.ko.xz sr9800.ko.xz zaurus.ko.xz
$ sudo ls /sys/bus/usb/drivers
sudo ls /run/current-system/kernel-modules/lib/modules/6.1.55-hardened1/kernel/drivers/usb/serial/
cp210x.ko.xz ftdi_sio.ko.xz
Technically you have no modem, it’s too early to talk about drivers.
Make sure your modem is properly connected and powered.
(post deleted by author)
One more info, Quectel EG25-G works fine on the same platform, for RG200U-CN i don’t see usb serial device. I am expecting usb connections are pin compatible between both mini pcie modem.
Can i get link of HW design document for RG200U-CN mini pci module?
Please make sure with lsusb we can see the 2C7C 0900
If you cannot see the VID and PID of the RG200U, and it means there is som hardware issue.
Please check the Quectel_RG200U-CN_Mini_PCIe_Reference_Design_V1.1.pdf.
