HTTPPOST using MC60
Dear Iunknown,
Thanks for your inquiry in Quectel forum.
About your quetsion, could you help to double check whether your URL is normal or not ? Or whether you use the HTTPS not HTTP URL ? The following is the AT sequence of HTTP for your reference, please double chek it.
And if you use the customize HTTP header, you can refer to the following example. Thanks!
