Hello
is there a way to make a http request via a proxy using QHTTPxxx AT commands ?
Thanx for your help
Radeocom
Hello
Thanx for your help
Radeocom
hello, could you please tell us your current firmware version or module type? thanks
Hi Niki,
we are using EC25-G with firmware EC25EFAR08A06M4G.
Best regards
Stephan
@fiona.fang Dear fiona, please help support this issue when you are available, many thanks~
Hi Niki,
I haven’t received any answer since last year… I’m still interested in having an answer…
Can you please help ?
Best regards
@Hayes add hayes to support this issue, thanks~
Hi @RadeoCom ,
Which proxy method are you referring to? I don’t quite understand. We can read HTTP response information through files.
I mean specifying an HTTP proxy when submitting an http request.
For example to send an MMS when the network operator specifies a proxy to use
Is it clearer for you ?
Stephan
I had the same issue and fixed it by setting up the proxy directly using AT+QHTTPCFG with option 5 for the proxy server and port before starting the HTTP session.
