How to verify Quectel EC25-AF(D) module Hardware version?
Thanks in advance.
Thanks in advance.
Hi zahoorhyder, thanks for your question
The hardware version cannot be queried directly through AT commands. You can open the shielding cover of the module. The hardware version of the module is standard inside. Generally, the shielding cover has a silk screen for V5.1. You can also open the shielding cover to query, thank you.
Opened the box, however i’m unable to locate the HW version either on stainless steel shielding cover or inside.
