Could you share with me the use case of UART2 of BG96?
Can UART2 be used in the same way as UART1?
Is the functional use decided such as for GNSS data output of UART3?
And could you give me some advice on how to check UART2?
For example, do they write something to the RXD to monitor the data output from the TXD, or connect the TXD to the RXD and run a loopback test?
