If anyone want to use the RG255C with the qmicli or the ModemManager, please do not try the qmi_wwan_q. Just use the native Linux driver. But you also need to add this
By the way…I noticed that the product description claims that this module features a “PCIE2.0 Port for Wi-Fi and Bluetooth” - what does this mean?
Means this module is capable to be used as Wifi and BT device? So, in device manager there would be a section wifi and BT for this module?
Ah ok thanks for clarification. I am looking for an affordable 5G Combo Modem or Smart Modem für Cellular, GNSSm Wifi6 and BT5 in M.2 form factor but it seems such device does noct exist
As I know, for such module you might need the Smart module such SG885(based on Qualcomm QCS8550) with Android 13.
But for personal or individual customer, Quectel would not provide the SDK.
I followed the above instructions and I have the following output on the ModemManager side. I have two main problems here;
In this output, signal quality always shows 0%. When I test with AT commands, I can see the signal strength at normal level.
-Another question is that the gps data is not fixed even though I wait for long periods of time.
Can you help me with these problems?
